Need help
54ford.rs
I have installed the ark springs with whiteline sway bars and end links but get clunky noises over every bump. I checked all the torqued and they are good but it is still there. I did remove the lower control arms and wonder if it is because the ball joints might not be seated correctly. Any thoughts or help would be most appreciated.
Sent from my SM-G965U using Tapatalk
That clunking noise you hear is from the endlinks, you need to put loctite on all eight of the treads of the lock nuts the torque them down. Here's a photo of what I'm talking about..
I heard the same thing from my whiteline endlinks, when you loctite them down an torque them let the car sit over night to set an you should be good..
Welcome aboard!!!!
5
54ford.rs
Thread Starter #4
Question. How much adjustment did tou have to do from the stock length?
That photo of the front endlink is set to stock length, the rear I set to stock length but when I had my aftermarket rims installed I had to make them shorter "close up" so the sway bar wouldn't hit the inside of the rim why the car is off the ground..
