- Houston
- TX
- Stinger GT2
@Shabib The issue you and the other member are mentioning, is not an issue per say, but rather an improper way of operating the shifter. Please refer to my post above (#12).
The shift by wire system behaves differently from your regular/mechanical shifter, we are all so used to. This shifter returns automatically to center position no mater which gear you have selected. Being a spring loaded shifter by moving it all the way backwards or forwards to select a gear and then letting it go (as shown in your video) will effectively move out of the gear you selected and put it on neutral, due to the spring load and force/momentum the shifter acquires by the sudden release of it. Hope this helps.
