Is proud to present to the Stinger community:
The ADD W1 Version 3 Baffled Oil Catch Can
Oil Catch can's catch the oil and moisture in the blow-by gas that causes carbon and sludge build-up in the intake system and engine. It's advanced design assures the best performance and keeps the engine clean even under hard driving conditions.
ADD W1 V3 Catch Can's come with a beautiful exterior redesign over the previous V2 model, sporting a gloss black finish with customizable colored ring inserts. The new design comes with a twister baffled filter which provides the best in oil and moisture filtration, by keeping the air longer! This ensures all the oil drops to the bottom of the can. The newly developed twister baffled filter is one of a kind and the only air filtration system on the market!
Easy to install, and easy to service. Highly recommended for tuned vehicles!
Features and Specifications:
ADD W1 V3 special engineered OCC
Revolutionary designed internal baffle "Triple Twister" chamber filter system
Closed loop system internal baffled Twister chamber filter Catch
Made from Lightweight 6061 Aircraft Aluminum
Fully customizable color insert rings available in 8 different colors
Prolong and protect the life of your engine
Baffled interior for the best collection of oil
Available in Red Black Blue Silver Gunmetal Purple Gold Green
Limited Lifetime warranty
Package Includes:
1x V3 Baffled Oil Catch Can
2x 9mm fitting
2x 15mm fitting
1x 15mm hose
Necessary Bracket & Screws
Internal baffle "Triple Twister" chamber filter catch
Installation instructions
All vehicles
