Is excited to present to the Stinger community:
Kia Stinger Eibach PRO-PLUS Kithttps://www.k8stingerstore.com/products/eibach-pro-plus-kit
This kit includes the Eibach PRO-Kit Lowering Springs and the complete Anti-Roll Kit for your Kia Stinger (PRO-Kit + Anit-Roll-Kit = PRO-PLUS Kit)
The Eibach lowering spring kit for the all-new 2018 Kia Stinger, improves your vehicle's looks and performance
Lowers your Stinger's center of gravity, reduces body roll in the turns, dive under braking, squat during acceleration, and gives the car a solid and secure feeling at all times
The Eibach Front/Rear Sway Bars affects the handling on the lower end of your Kia Stinger suspension
Thicker construction over stock sway bars keeps your Stinger flatter in turns when cornering by decreasing body roll
Both Front & Rear Sway bars are a tubular solid construction and have a two-way adjustment
Specifications:
Includes (1) set of 4 Eibach lowering springs + Eibach front & rear adjustable sway bars
Drop Height: 1.4? Front/1.2? Rear
Rear Sway Bar Thickness: 19mm/Front Sway Bar Thickness: 25mm
Easy to install and are a direct replacement
1 Million-Mile warranty by Eibach
2018+ Kia Stinger 3.3T
