Is very excited to bring to the Stinger community:
The Kia Stinger ARK Performance GT-F Lowering Springs
ARK Performance offers high quality lowering spring kits that provide a clean drop, comfortable ride, and greater performance. ARK GT-F Lowering Springs are designed to provide drivers with a dramatic improvement in handling characteristics and cornering. Drivers will feel a significant increase in steering response, better cornering grip entering and exiting out of turns with reduced body roll, and a lowered center of gravity while maintaining smooth and comfortable ride quality for daily driving.
ARK Performance GT-F Lowering Springs are designed by their suspension engineers and tested by professional drivers to find the perfect ride height and spring rate to deliver the best ride quality and performance without neglecting the driver's safety on and off the track. Their springs are the perfect combination with your OEM shock absorbers. They provide an excellent stance with your stock or aftermarket wheels while keeping your tires on the road for maximum grip.
Each spring is made from the highest quality materials, with the leading coiling technology, and is powder coated to prevent corrosion. ARK GT-F Lowering Springs for your Stinger provide the ultimate suspension balance to give you confidence on any road or course.
Features and Specifications:
Includes (1) set of 4 lowering springs
Improves Handling and Cornering
Reduces Body Roll
Works With OEM Shock Travel
Comfortable Ride Quality
Spring Rates: 3.2 kg/mm Front/4.9-5.8 kg/mm Rear
Drop Height: 1.15? Front/1.0? Rear (AWD)
Drop Height: 0.75? Front/0.75? Rear (RWD)
2018 Kia Stinger (All Trims)
